show ntp server
show ntp server
Description
Shows the NTP servers configured on the switch, including the name, IP address, key ID, and index.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
N/A.
The following command shows the NTP servers configured on the switch:
# show ntp server
VR Name               Name                      IP Address           Type      Flags  Key Index
VR-Mgmt               45.125.255.53             45.125.255.53        Server    I      -
This command was first available in ExtremeXOS 12.7.
Platform Availability
